Metric Gauges Displays
Place your display templates here with a screen shot of it for previewing.
Steeve_Civic
Post by Steeve_Civic »
All your displays are in Farhenheit and PSI.
I use Metric (BAr and Celcius) how can I change displays please?
Thks
Re: Metric Gauges Displays
select the gauge you want to change, right click and you can change the caption. You will also have to change the units in Options, Settings amd in the sensor window.
Steeve_Civic
Thank you, just changed the caption.
Moreover I need also to change the value min and max otherwise I still have numbers in PSI?
you will have to change all parameters associated with the units you want to change.
Steeve_Civic
OK
I need to change in Options-Sensors and options-Setting-Units then change on the gauge with a right click correct?
correct
