INNOVATIVE LMX WIDEBAND INSTALL
Posted: Fri Nov 09, 2012 4:08 pm
by PROTO TYPE FI
How do i tie in the wideband signal wire to my s300 v2 i have the analog input harness but do i adjust anything in sensors?
Re: INNOVATIVE LMX WIDEBAND INSTALL
Posted: Fri Nov 09, 2012 4:49 pm
Posted: Fri Nov 09, 2012 6:12 pm
by PROTO TYPE FI
yes it has 14 to 1 listed on the analog sensor list but up at the air fuel list on o2 reading it does nothing i dont understand exactly what this means
Posted: Mon Nov 12, 2012 10:21 am
You will only be able to datalog this as an analog sensor. You can create a new gauge on the display window to show the analog input and label it however you want.
Posted: Tue Nov 13, 2012 7:12 pm
by PROTO TYPE FI
Ok got it done i have a 94 INTEGRA LS pr4 ecu which wire do i cut and tie in the narrow band signal for the ecu o2 The LMX has both out puts
Posted: Wed Nov 14, 2012 2:12 am
by Luke
you can use both outputs.
you can wire the narrowband output to D14 and the wideband to D10.
i have hooked up my LM-2 to D14 via the tuner-harness. some say, that i won't get the whole reading, since D14 shall only read up to 3.8V, but seriously: who needs AF above 16?
best regards Lukas
Posted: Wed Nov 14, 2012 11:14 am
by PROTO TYPE FI
I read that you have to modifie the board to use d10 th eeld for a wwide band reading? is that just because it only reads sooo much voltage?
