INNOVATIVE LMX WIDEBAND INSTALL
PROTO TYPE FI
Post by PROTO TYPE FI »
How do i tie in the wideband signal wire to my s300 v2 i have the analog input harness but do i adjust anything in sensors?
Re: INNOVATIVE LMX WIDEBAND INSTALL
Have you read the information in the help file?
http://www.hondata.com/help/smanager/an ... sub=analog
PROTO TYPE FI
yes it has 14 to 1 listed on the analog sensor list but up at the air fuel list on o2 reading it does nothing i dont understand exactly what this means
You will only be able to datalog this as an analog sensor. You can create a new gauge on the display window to show the analog input and label it however you want.
PROTO TYPE FI
Ok got it done i have a 94 INTEGRA LS pr4 ecu which wire do i cut and tie in the narrow band signal for the ecu o2 The LMX has both out puts
Luke
Post by Luke »
you can use both outputs.
you can wire the narrowband output to D14 and the wideband to D10.
i have hooked up my LM-2 to D14 via the tuner-harness. some say, that i won't get the whole reading, since D14 shall only read up to 3.8V, but seriously: who needs AF above 16?
best regards Lukas
PROTO TYPE FI
I read that you have to modifie the board to use d10 th eeld for a wwide band reading? is that just because it only reads sooo much voltage?
