Map comparing
Posted: Thu Nov 08, 2012 4:36 am
by Nazul
Is there a way of comparing 2 maps and thus the fuel maps ignition maps and cam degree maps with each other in a simple way with hondata?
Re: Map comparing
Posted: Thu Nov 08, 2012 10:30 am
Compare calibrations will tell you if they are the same or not.
If they are different I just open two copied of KManager and switch between them.
Re: Map comparing
Posted: Fri Nov 09, 2012 2:48 am
by Nazul
2 copies of kmanager is impossible on XP.
If you start a new one, it just opens the one already in the taskbar.
Re: Map comparing
Posted: Fri Nov 09, 2012 9:31 am
It is possible - I often do this.
Re: Map comparing
Posted: Fri Nov 09, 2012 9:35 am
by Nazul
I need to double check this then, thanks Hondata.
But maybe its easier if there is an option in the compare section when double clicked on differences, it makes a summary.
Or that it opens 2 screens with the maps next to each other, though u do need a big screen :D
Greetz
Re: Map comparing
Posted: Fri Nov 09, 2012 10:50 am
You can only open 2 copies of Smanager and FlashProManager. K-Manager will only allow one instance.
Re: Map comparing
Posted: Sat Nov 10, 2012 8:35 am
by Nazul
Can this be added in a future release?
Re: Map comparing
Posted: Sun Nov 11, 2012 7:29 pm
Sorry; Yes.
Re: Map comparing
Posted: Mon Nov 12, 2012 3:19 am
by Nazul
thnx guys
