k20a2 I/H/E buddyclub spec 2 cams, rbc+karcept+70mm TB
Posted: Sun Oct 28, 2012 8:58 pm
by EVLDC5
hi i have a dc5 type r with buddyclub spec 2 cams, I/H/E with rbc +70mm TB and injen CAI in need of a good tune, and AC/TEMP GAUGE not working,
help anyone?
Re: k20a2 I/H/E buddyclub spec 2 cams, rbc+karcept+70mm TB
Posted: Mon Oct 29, 2012 8:47 am
In 'Parameters', enable the 'Multiplexor' setting.
Posted: Tue Oct 30, 2012 12:04 am
by EVLDC5
its already in "Normal" operation, Temp gauge works now, but still no a/C? i mean the ac clutch is not grounding, even the condenser fan not turning on, i need some help guys, its starting to get really hot here now,
Posted: Tue Oct 30, 2012 8:49 am
Check the ECU is getting the signal from the AC ('ACSW' in sensors). If not, then the low pressure circuit might be preventing AC from engaging.
Posted: Tue Oct 30, 2012 4:52 pm
by EVLDC5
Hondata wrote:Check the ECU is getting the signal from the AC ('ACSW' in sensors). If not, then the low pressure circuit might be preventing AC from engaging.
just checked, ACSW in sensor, ecu is not getting signal when ac switch is pressed on, what do you mean by the low pressure circuit?
and yea, when i press the ac switch, nothing happened, condensor fan dint turn on either, but when i ground the ac compressor clutch, it clicks in, btw car is a dc5 03 type r,
Posted: Wed Oct 31, 2012 9:26 am
Look at the factory manual - a low / high pressure cut out protects the compressor.
Posted: Wed Oct 31, 2012 9:55 am
by EVLDC5
Hondata wrote:Look at the factory manual - a low / high pressure cut out protects the compressor.
so how do i fix it? please its really starting to get hot here in sydney,
Posted: Thu Nov 01, 2012 9:18 am
Follow the trouble shooting steps in the helms manual.
