B18C6 on EG6 EUDM
NòSe
B18C6 on EG6 EUDM
Post by NòSe »
Hi, i've a problem.. i've an eg6 with b18c6 european R engine with full exhaust, aribox and vafc apexi.. i upload a calibration in hondata with car in motion and check is light with automatically the car is off..
i start the engine and three second later, the check is light..
the error codes are: electrical load detector and knock sensor..
where is the problem? and have you a calibration for my european b18 with this upgrade?
excuse me for my english but i'm italian
thank you
Nazul
Re: B18C6 on EG6 EUDM
Post by Nazul »
Why using a vafc apexi with hondata?
You can do anything with hondata which the vafc can so get rid of it.
on what fuel does this car run?
What is the complete code on the side of the ECU?
NòSe
Post by NòSe »
because i'm fitting the hondata today and after i had a ecu stock..
now i'm p28 ecu
check light it's off.. i'm deleted a knock sensor in smanager but i need a new calibrate for my b18c6 with full exhaust 4-2-1 hitech and 60mm line and air box with cotton filter
can you help me?
thank you!
Luke
Post by Luke »
you can simply disengage the ELD and knock sensor, since the european models don't have one or the other sensor.
with your setup i would recommend to find a tuner and get it tuned. this would gain most of the power.
if you can find a similar map from another user? hard to say.
best regards Lukas
NòSe
Post by NòSe »
ok thanks for info ;)
Nazul
Post by Nazul »
No engine is thesame, even if the setup is thesame.
So dont use another map of a car which has thesame setup.
Best power is achieved with invididual tune of the car.
