TC on S2000 Kpro not working
civicRSA
Post by civicRSA »
TC out is wired to S2000 Kpro ecu pin A30.
ELD is disabled and TC enabled in Kpro. When datalogging and testing TC out with the test function the ELD voltage will change from 0-4V
but the %overslip and TC out will not display any values. Stays at 0.
Kpro manager 3.1.6
TC Manager 1.0.3
PS: Forum will not allow the upload of a .tcc file.
Re: TC on S2000 Kpro not working
Fixed. I'll make a new release tomorrow.
You should be able to post .tcc files on the forum.
Max358
Post by Max358 »
I have the same problem. I have RSX. After the upgrade, the name of the ELD input correctly. But Traction Control just does not work.
When you connect the computer to the ECU, should show Kmanager Speed ​​TC LF, TC RF ...?
I took a screenshot when driving 40 km\h
ELD.V 0.25-0.29
Please help find the problem
maksss@me.com
Thank you!
It is not the same problem.
Are you connecting to the Traction Control for datalogging?
The ELD voltage should never by 0-1V when using Traction Control, only 0V and above 1V.
Max358
Post by Max358 »
I will try tomorrow to make datalogging...
Do I understand that the TC should work when loading settings for RSX 2006? All other settings can be left at default?
In Kmanager I just turn on the TC pin and choose ELD (E15)? That's it?
If you turn off all the wires from the ELD, Kmanager shows 4.55V (idle)
Stock wire is powered 2.5V (idle)
With the orange wire connected to the ELD, Kmanager shows 0.25V (idle)
Start your own thread about this. Include all files used and include a datalog showing the problem.
