TC on RSX Problems
Max358
TC on RSX Problems
Post by Max358 »
I started writing about my problem in this topic
http://www.hondata.com/forum/viewtopic.php?f=42&t=14710
Test in TC manager (ECU command output test) helped make sure that the right comes on ELD.
But if I turn on the test over slip, the only change in the value Kmanager ELD, is this normal? I enclose a screen shot. The machine is not a standstill, the engine on idle. including tests over slip.
After I recorded datalog with slip on 1 and 2 gears. (The extension csv is not allowed, i reneme .csv to .kal)
Thanks!!!
Re: Is this enough for working Traction Control?
The default settings in KManager should work for you.
Max358
Re: TC on RSX Problems
Post by Max358 »
I update topic, help please!
Thanks!!!
Max358
Post by Max358 »
Yes of course (3.2.0), the settings uploaded a new version with a laptop
kmanager should show what that other information besides ELD.V?
Are you datalogging with both KPro and TC plugged into the USB?
Max358
Post by Max358 »
no, only TC. do today, thanks!
Max358
Post by Max358 »
I plugged KPro and TC plugged into the USB, Speed ​​began to show in the parameters Kmanager, the settings uploaded to ECU. But things are still did not help me.
Datalog of Kpro attached.
In Moscow cold weather now, slippery :)
Thanks!!!
YOu need to post your calibration, datalogs as well as the traction control calibration file used.
Max358
Post by Max358 »
I attach my firmware Kpro
And the configuration file TC (default "RSX" 2006 2006), there is almost no change settings
CHeck yout TCC file, as it appears you have it set to a rear wheel drive vehicle.
Max358
Post by Max358 »
This is the default value for "RSX2006") Thank you! In the evening, I can check!)
Hurray!!! TC is working!!!
Hard to believe I did not notice that the selected rear-wheel drive.
You are planning fix the default setting for "RSX 2006"? If you look "Slip setup" Cornering for RSX is very similar to S2000
Very much like that would have been a settings file for my car with basic settings made ​​by experts
Max358
Post by Max358 »
Traction Control Calibrations which I use for RSX turbo (DC5)?
What is the difference and 2006civicSC 2006civicTC? What kind of car models?
Thanks!
2006SC is for a 270 hp supercharger car. 2006TC is for a 500+ hp turbocharged car.
sass
Post by sass »
Max358 wrote:This is the default value for "RSX2006") Thank you! In the evening, I can check!)
Who is your tuner in Moscow?
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
