KManager Help File Typos.
Screech
Post by Screech »
I'll just edit this if I find move.
  • introductiontocalibrations.htm
    When KManager is installed, this file extension is associated with KManager so that you mat open a calibration by double-clicking on it.
    "mat" should be "may"
  • tuningyourvehicle.htm
    VTC (variable timing control) is another mechanism used by Honda to increase engine output which decreasing emissions and fuel consumption.
    Perhaps "which" should be "while", sounds more correct to me anyway.
  • tuningfueltables.htm
    It it necessary to use and lambda meter (air/fuel gauge) to tune to fuel tables.
    Thinking "and" should have been "a".
    Certain K-Series engines utilize and wide-band oxygen sensor which is useful for tuning, otherwise most dynos are equipped with a lambda meter.
    Looks like another "and" where "a" should be.
    It is best to tune so that the air/fuel plot are fairly flat.
    Should be "plots are" or "Plot is".
Not done reading help file, but will provide more as I see them.
