99 Civic Si - B16A3
Posted: Mon May 17, 2004 4:29 pm
I've utilized the search and only came up with about 7 topics, none of which seem to have the answers I'm searching for.
The answer I would suspect will take someone a few minutes to type (Im guessing, since after all I am completely lost) so let me say that I greatly appreciate the time you spend on your response.
I have a 99 Civic Si which I plan to use the s200 w/boost. The ECU that is/was in it is a P2T-A11. I've already purchased a P28 and chipped it, however, I can easily enough find another ECU if it is recommended (and please do recommend it if there is a better ECU to use as the Hondata ECU in my particular case and for curiousity sakes, let me know why its better than the P28).
Questions:
1. What ECU would you recommend for me to use? (and why if you don't mind, note, I am NOT questioning your suggestion, I am just curious and want to expand my knowledge)
2. With the ECU you recommended, what things will I need to change out (if anything) such as distributor, etc. (I believe I read someone actually had to change out their distributor??)
If there is anything else you feel I should know, I am most definitely all ears and appreciate your response.
Questions:
