Weird Cel problem
b18flip
Weird Cel problem
Post by b18flip »
Recently I've been experiencing some odd issues with my setup. It's been on and tuned for about 1.5 months now, and recently it's been giving me a Cel but the light won't blink when i jump the harness. The idle tends to bounce around, won't rev passed 3.5k i believe, and runs like crap. I checked to make sure all the connections/soldering was ok on the ecu and obd1-obd2 harness. I also tried idling the car with the stock obd2 p72 and it only gives me a cel 65 (secondary o2 header) which expected since it's not installed.
Setup: 01 GSR, basic turbo kit, hondata s200b, p72, ob2-1 harness from honda-tech member "blown90hatch"
turbosi92
Re: Weird Cel problem
Post by turbosi92 »
b18flip wrote:Recently I've been experiencing some odd issues with my setup. It's been on and tuned for about 1.5 months now, and recently it's been giving me a Cel but the light won't blink when i jump the harness. The idle tends to bounce around, won't rev passed 3.5k i believe, and runs like crap. I checked to make sure all the connections/soldering was ok on the ecu and obd1-obd2 harness. I also tried idling the car with the stock obd2 p72 and it only gives me a cel 65 (secondary o2 header) which expected since it's not installed.
Flip,
what map sensor are you using?
b18flip
Post by b18flip »
i'm still using the stock map sensor
turbosi92
Post by turbosi92 »
b18flip wrote:i'm still using the stock map sensor
What PSI you running? I would get this everyonce in a while and I know it is the map sensor as I was boosting to much on the stock sensor. I was pushing it to the limits. It would throw a solid CEL and go away after a minute sometimes. I narrowed it down to that.
