Possible Map Flashpro Map/firmware Issue? Car shutting off!
silvermonster
Post by silvermonster »
Hello everyone. I am having sort of an issue with flashpro and possibly a firmware. Here is a brief description of the issue.
If I'm cruising down to a stop, I let up on the gas and push down on the clutch. Most of the time, the rev would stop at 1k however there has been times when it would fall down further and not recover. When this happen, the car shut off. I am able to restart it without any issue.
Also on the freeway, if I'm cruising at 70. I let up on gas pedal, push in my clutch, the car would stall as well. Same thing as above. Most of the time, it would stay at 1k however if it goes below 1k, it would not recover to 1k and would die.
It doesn't happen all the time and but it has done it enough to be worried and try to find a solution.
I have ruled out the following:
Replaced Primary O2 with honda
Check and replaced spark plugs
replaced pcv valve
check for exhaust leak or any time of vacuum leak
I used an etuner service and was using his map for the last 8 months without any issue. This popped up out of the blue with no modification done to the car since the final tune. Also when using this map, it would stall out more often.
When I used the stock TODA calibration, it wouldn't do it that often. I thought it was the map that was the issue seeing it would stall out more on the etuner map. When loading the toda cal, it didn't stall on me but yesterday it stalled on me a few times for the first time so I have to rule out not being a map issue.
I had a tuner take a look at the map and he might think its related to something throttle position or maybe firmware related.
Sorry for the long post. Any suggestion is greatly appreciated. Thank you.
Re: Possible Map Flashpro Map/firmware Issue? Car shutting o
Do a leak down and compression test. You may have an actual engine problem. Try returning it to stock, if it still does it you know it has nothing to do with the FlashPro.
silvermonster
i'll do the compression test and leak down. I'm going to return it back to stock.
If it doesn't do it with stock map, then do you think its something with flashpro?
This does not sound like a FlashPRo specific problem. It is most likely mechanical or tuning related.
Your long term trim is -10%, which indicates that you need to do more closed loop tuning.
The short term trim is all over the place, but there are no periods of steady driving, so it may not be a problem.
Fuel trims change a lot when the AC or fan kicks on at 5:05, which would indicate the dead times are not quite right - what injectors are you using?
silvermonster
i am using stock injector. Everything is stock except intake and test pipe. could it be something related to throttle? tps sensor perhap. Maybe the ecu think the throttle is still open when i let up on the gas. Doesn't that cut off the injector when my foot is off the gas pedal?
compression test was done last night and it was consistent through all 4 cylinder.
The throttle and injector cut off look fine.
I think it just needs tuning.
