Neptune Tuner View 2 + Wireless pair up
Lyle_57IAL
Post by Lyle_57IAL »
Hey guys.
Currently own a P28 S300. Very interested in the Neptune Tuner View 2. Firstly
*Will these pair up directly with the S300 do you you need a extra hardware addition?
*What are the electrical cable teminations like? Does this recieve its power purely throught the USB? or does it have a external 12v power source.
* What is the deal with blue tooth connectivity? is this extra hardware you add to the ecu so the tunerview will be able to datalogg without a usb cable?
If so, how reliable are these units? easy to install to the ecu? is it plug and play or will require in depth soldering?
*Can the tunerview show everything that the hondata can show? specifically live IAT and ECT fuel compensations?
*if i install via usb, Can i put a double adaptor on the ECU and have both a laptop & this unit connected at the same time?
* what is the main difference between these three models?
Tunerview II Dash Kit Large [NTV2DASHLARG] - $159.00 : Conversion Harness.com, Your Source for OBD ECU Conversion Harnesses and more
Tunerview II Dash Kit Regular [NTV2DASHREG] - $139.00 : Conversion Harness.com, Your Source for OBD ECU Conversion Harnesses and more
Tunerview II [NTV2] - $199.00 : Conversion Harness.com, Your Source for OBD ECU Conversion Harnesses and more
cheers guys
Re: Neptune Tuner View 2 + Wireless pair up
You will need to ask these questions to the maker of the Tunerview.
