Flashpro Help
honda_racer07
Flashpro Help
Post by honda_racer07 »
Hi guys,
Here's the info to start with before we get to my problem.
Ser# FP-SI-US-11251
version - 1.1.9.6
calibration added below
2007 civic si sedan FA5
stock with tune
basic h,e i ,throttle body
PROBLEM:
I have had several issues with re-flashing the vehicle. I attach the unit to my computer make the adjustments take it back to the vehicle and it won't re-flash. I have had the dlc connector replaced ( not to difficult as I work for a Honda dealer in IL in the service dept.) because this problem has been an on going thing with your product.
Before you guys said it was the wen pin, sometimes this thing will work and sometimes it won't makes me think at this time there has to be some intermittent problem inside the unit. Here's one thing that might help I can datalog all day long when ever I plug it in, but when I want to just want to re-flash it won't. It starts the cycle then stops, Any help would be greatly appreciated, as I'm in the middle of tuning a new throttle body and need it to work consistently. oh, this flashpro unit is baby'd and take extremely well care of!
Thanks honda_racer07
Re: Flashpro Help
First, 1.1.9.6 is 10 months old and you should be using at least V1.2.8
Attempt to flash the vehicle, and it if fails, use the send support information function immediately afterwards.
honda_racer07
Re: Flashpro Help
Info sent please keep me updated.
Thanks!
honda_racer07
Re: Flashpro Help
Correction, I will download the new software then if a problem continues I'll resend the info.
honda_racer07
Re: Flashpro Help
Well I updated software and still have the same problem won't reflash. also resent the infor to tech support with file. But, now it tells me wen pin this seems to be the standard answer as I mentioned before I have replaced the DLC connector and can't believe it's still the problem and why over the last few days has it been working just fine. Seems to have an intermittant problem on the wen pin possible in unit. Again any help is greatly appreciated let me know your findings.
Re: Flashpro Help
Got the support information, it still is the WEN pin. We'll email you shortly about it.
Re: Flashpro Help
Have you moved the ground as recommended?
http://www.hondata.com/flashpro_tsx_upgrade.html
honda_racer07
Re: Flashpro Help
Yes I have. Email is the quickest way to get hold of me also.
