Big problem with my tune
Posted: Sat Sep 01, 2012 2:57 pm
No matter how I tune, my afr fluctuates 10 to 17
when i tune the idle at 14.7 and rev to 3500-850, the afr in the idle goes back to 10 and then it goes up to 17 and then down to 14.7 and so on.
then when drive with first gear and rev the car up to 2000, the engine begins to stutter at over 2000 the afr is going down to 10. no matter i tune i cant fix the problem.
First we thougt that my Ecu ist damaged and i boght a new p28 and socket it. But the problem don't solved. Then i have bougt new injectors (rc650) but its the same problem -.-
After i have entered other injectors dead time and my car runs fine for the first miles but after a few miles the stutter started again and at some point during the ride, it went away again.
although we tuned the car in the idle at 14.7, the afr varies from 10 to 15.
I hope someone had this problem to and can give me tips.
My engine:
d16y8
rc 650cc
hondata 4 bar map sensor
aem boost solenoid
hondata s300
honda crx del sol 1996 (obd2)
kkk k04 turbo
p28 ecu
walbro intank fuel pump
please help mee my car is since january in the garage :(
When i plug in my oem p28 G03 Ecu with oem 240cc injectors and oem map sensor, car will drive without stutter or something like that.
Thank you very much.
My engine:
d16y8
rc 650cc
aem boost solenoid
hondata s300
kkk k04 turbo
p28 ecu
