05-06 Type S Gearbox in an 03 DC5 Type R
Posted: Tue Aug 28, 2012 8:09 pm
by its_ish
Hi,
I recently had to replace my gearbox in my DC5 Type R with a Type S high frequency type (countershaft driven speed sensor) and now the speedo/cluster does not work properly. I have disconnected the wiring for the cluster as it is showing erratic reading despite selecting the countershaft speed sensor sensor option in the MISC option of Kmanager. I have a PRD ECU with a kpro and would like to know what I need to do to have the cluster/speedo to function correctly. Will I need to use a speed sensor converter like a Dakota, Ktuned or Hybrid Racing or will I need to re-wire my harness? Please advise.
Re: 05-06 Type S Gearbox in an 03 DC5 Type R
Posted: Wed Aug 29, 2012 9:03 am
Use the engine side case from your old transmission with the speed sensor.
Posted: Thu Aug 30, 2012 5:02 am
by its_ish
Is that the only way to make the speedo work?
Posted: Thu Aug 30, 2012 8:44 am
It is the best way and the only way we will recommend.
Posted: Thu Aug 30, 2012 4:34 pm
by its_ish
Ok, noted.
However, I wanted to explore other options.
1. use of a speed converter (hybrid, ktuned, dakota)
2. Use 05-06 Hondata Kpro
I know you dont recommend these options but is there a possibility they could work?
