error codes 10 and 41 wont go over 2500 rpm
scott12757
Post by scott12757 »
got a fully built b18c blew 240 compression all the way across , p28 from hamotorsports and im running the itr stock basemap , any suggestions to get it over 2500 ? im guessing the codes are preventing it .. just looking for a quick fix for now til i get it dyno tuned
Jimmy50941
Re: error codes 10 and 41 wont go over 2500 rpm
Post by Jimmy50941 »
do you have the intake air temp sensor hooked up? and you can disable the o2 heater in the closed loop tab, and that might get rid of the code 41.
scott12757
yeah i have everything hooked up , double checked .. but i disable code 41 like you said but code 10 is being lame , im not sure whatsup tho i had a hole in my short ram intake plugged it up. It made a difference in the temperature ,double checked all my fittings and everything yet still throwing the code -___- im also guessing that is why it will not rev over 2500 rpm.
Jimmy50941
did you upload the calibration with the test upload button? because that will set the rev limiter at 2500 also.
