Warnings not working
05typeR
Post by 05typeR »
I have setup and changed both the display min/max and the warning min/max I would like to see while data-logging/tuning but when the gauge should display red its still green.
anyone had this problem?
UPDATE:
I swapped around the Value min/max with the warning min/max and it works as it should with the IAT and the AN0 (AFR Sensor), I tried it with the INJ (ms) but that didnt work.
I have also tried it on two PCs with Ver 3.1.2 of the software.
Re: Warnings not working
You will need to post your display template file for us to see how it is setup.
