injector problem
Posted: Sun Aug 12, 2012 3:21 pm
by raidentim
after installing some rdx injectors and doing a reflash my number 4 injector isnt firing. iv swapped injectors and pig tail to different cylinders, checked resistance in wiring to ecu pin#9 (yellow) to injector, B+ with key on and did ecu relearn. Could it be an ecu or flashpro problem?? thanks
Re: injector problem
Posted: Mon Aug 13, 2012 10:15 am
This will not be a problem with the FlashPro. You have probably miswires or shorted one of the wires and damaged the ECU. Unlock the FlashPro from the ECU before replacing it or you will not be able to use the FlashPro with the new ECU.
Posted: Mon Aug 13, 2012 4:07 pm
by raidentim
Thank you for your quick response. I just wanted to rule out the flashpro as i am not aware of any problem with it. As far as my wiring goes everything was done right and and the ecm was disconnected from the injector circuit when the work was being done. Anyway thanks again
