VSS calibration
Brock
VSS calibration
Post by Brock »
I think all versions of FlashPro should have a provision to change the VSS calibration to accommodate different tire sizes and/or gear changes.
Re: VSS calibration
For some vehicles, the speed sensor signal goes to the cluster directly and the ECU cannot change the speedometer / odometer calibratrion.
Brock
Re: VSS calibration
Post by Brock »
I probably should have made the comment specific to the TSX. In which case the VSS goes directly to the ECU, which generates speed data for the cluster. It seems to be getting more common for people to swap the gears in the TSX trans with RSX or Civic Si gears.
Re: VSS calibration
07 or 09 ?
Brock
Re: VSS calibration
Post by Brock »
First gen... 07' ~ 08'.
Re: VSS calibration
Ok, I can add the dash speed fairly easily.
Brock
Re: VSS calibration
Post by Brock »
Hondata wrote:Ok, I can add the dash speed fairly easily.
