SManager V2.1.5
SManager V2.1.5
This release is mainly so that the s300 can be used with our Traction Control, which is due for release at the end of the month.
V2.1.5 (21 Sep 2012) changes:
  • Added tool tip window to lambda and fuel overlay.
  • Added Flex Fuel support.
  • Added support for traction control.
  • Improved Hondata Vault behavior when searching and downloading files.
jiggacivic
Re: SManager V2.1.2 (beta)
Post by jiggacivic »
why when installed it still says 2.1.1.0
looks like the version numbers were not updated when it was compiled...it is the newer version though if it has the flex fuel tab in parameters
jiggacivic
k
oskrB18
Post by oskrB18 »
Is not working.
In the troubleshooting section is the SManager2-1-1 version. This is the latest by far I think
DB7 LS/Vtec
Luke
Re: SManager V2.1.5 (beta)
Post by Luke »
when datalog is on and the USB cable is pulled out (happend yesterday evening) the software just hangs up.
only reboot help. thank god for the SSD :D
best regards Luke
FreshDA9
Post by FreshDA9 »
Hmm i tried logging into the vault with my screen name here and it re directed me to the forum and wants me to make another account? is there anyway i can use my screen name currently?
EFI-101 & Advanced Certified*
It is case sensitive.
FreshDA9
Post by FreshDA9 »
Just wanted to say there is a bug somewhere.
Tuning an integra tonight with the beta, some time after starting I made a change in the parameters then a cel light came on (nothing in the error codes). shut off car closed smanager and reopened. upoaded the file i was working on and failed to upload. Loaded the original map and uploaded said, "Firmware update" so it took like 10in to do an update and after it completed said it failed and re did a firmware update. this repeated 1 more time.
shut car off, pulled ecu, restarted computer. Same issues cannot upload map. Reverted back to stable release loaded original map No issues and no firmware updates etc! Finished the car with no problems.
Using the beta version of software with everything connected and the ignition on, go to Help, and click on send information to Hondata support. Include a detailed description of the problem.
FreshDA9
Post by FreshDA9 »
wish i would have known of that sooner spunk. already reverted to the stable release and finished the car and sent it on its way.
