Where to run switched ignition 12v source for Boost solenoid
Posted: Sat Jul 28, 2012 4:51 am
by WaZe_One87
So I just got my Boost Solenoid kit from K series parts.com in Colorado Springs.
So now I am planning out my install as i await for my ECU to come back from being socketed for boost control by Hondata. I understand everything as far as vacuum lines, and running a pin to the ECU to A11. However I'm curious as to the cleanest most reliable 12v ignition switched source to use. Should i tap into the ignition with a in line 10A fuse? Or should i extend the wire and try to run to my under dash fuse box? I think the fuse box would be a cleaner install, but where should i send it, and will extending the power wire further have any negative effects on the solenoid opperation? Below are the under dash fuse/relay diagram and list of fuse components. Let me know what you guys think.
Also, on a side note, i noticed my solenoid kit didnt come with any pins to attach to the wire. Are there any places i could pull a pin? I have a couple unused sensor clips that have cut wires. . would they be the same size as the ECU pins if i were to pull them individually? Unfortunately I should have asked for Hondata to send a couple back when they send my ECU back lol. That way the turn around time is about the same as the computer.
Re: Where to run switched ignition 12v source for Boost sole
Posted: Mon Jul 30, 2012 9:43 am
Check C915-C919, one of them will be switched power. No other pins will fit the ECU plugs. You will need to get the proper pin, or get a pin and some wire from a junk yard car (the best option).
Posted: Mon Jul 30, 2012 9:49 am
by WaZe_One87
Thanks spunkster. So there won't be any weird effects from running the wire a little longer then? I can't imagine there would be but considering how specific the temp and vacuum lengths are, doesn't hurt to ask.
Posted: Mon Jul 30, 2012 11:07 am
It will not matter
Posted: Wed Aug 01, 2012 12:48 am
by WaZe_One87
Just wanted to throw some praise into this post. HONDATA IS FREAKING AMAZING! so my ecu came back today and low and behold. . . they sent some ecu pins with it! I dont know if they saw this thread or if they just do that as a standard. . . but either way they gave me exactly what i needed. Saving me time and a little bit of money even! haha anyways thats all i had to say. . Just kinda happy about my surprise haha. Thanks Hondata!
