S300 V2 analog inputs for Aem wideband
Posted: Sun Jul 22, 2012 5:57 pm
by Wego5
I can't seem to find any definite clarification. I plan on using the analog pigtail, do I just plug it into the S300 board and connect to the A0 wire? Do I need to re-ground one of the two ground wires on the pigtail?
Any help is appreciated
Re: S300 V2 analog inputs for Aem wideband
Posted: Mon Jul 23, 2012 9:41 am
http://www.hondata.com/help/smanager/analog_wiring.htm
Wire the signal to the input you wish to use. You probably do not need to wire any additional groun d to the AEM other than the standard power and ground.
Posted: Tue May 14, 2013 1:53 pm
by Presicion6266
Hey Spunkster dose this wiring apply same on the aem 30-4900 witch is the fail safe & AFR/Boost in one.
I just need to know witch wire goes where.
Posted: Tue May 14, 2013 3:25 pm
Those analog inputs are for datalogging only. You cannot run closed loop from them or use any lean protection.
Posted: Mon May 27, 2013 1:53 pm
by abdullahjamo
does that mean that its only of use when the s300 is hooked up to a laptop? if so then how do I hook up a AEM 30-4100 to the ECU for real? and should the analog input be removed while driving normally? could it hurt the ECU?
Posted: Tue May 28, 2013 10:05 am
You do not have to disconnect the analog inputs when driving.
Basic details on wiring a wideband can be found at:
Just susbstitute the correct wire colors for the wideband you have.
