same dead lights on 2 different ecu with s300 socket testeer
Posted: Fri Jul 20, 2012 4:12 pm
the first ecu was a p28-a54. i used a hakko 808 to desolder it. everything came out clean. then i put the socket tester i had a few lights out on the bottom. going from the bottom right in the second light is dead, the 3rd light is extremely dim and the 6th light is dead.
i desoldered the board and resoldered it again and nothing.
figured it might have something to do with being an automatic ecu.
i did a few more boards that the all tested perfect.
today i went and did a p28-ao2, when i first hooked up the tester everything was light up. when i went back and looked at it i had the exact same dead lights. wondering if this is a common problem
