Anybody want to check my datalog? Im concerned about it
Posted: Thu Jul 19, 2012 9:11 pm
by WaZe_One87
Basically i settled for a B16 750CC 5psi on t3/t4 57trim turbo for $300. Because of mishaps, then inconsistant prices that would double every ten min. . . (exageration, but not too exagerated.) I took the car as is, "tuned" for the 5psi wastegate spring. . . but he said it stops making power before 8000 rpm and shouldnt even rev to it. I have a fully built Head and Performance cams, along with a sleeved, forged, and balanced bottom end. Im in Colorado, so altitude plays minor issue, and so does using E85 with low boost, but im making LESS power than my previous tune did with less than 5psi and 85octane pump gas.
^^Original tune on bone stock B16 using 85 Octane pump gas^^
^^New tune, B16 RC750cc injectors, Fully built with head work and Brian Crower Stage 2 cams, Sleeved and forged bottom end. ^^
So tell me. . . did they just say it was tuned? Did i pay $300 for virtually nothing? Look how much power and torque drops well before redline. I wont be going back to this tuning shop because their price quotes kept jumping up higher and higher . . . so i told them, give me the tune on the 5psi wastegate spring (same as before) and let me be on my way. . and he was "dynoing" for another 1.5hours to get that result. I feel i've been taken.
Also here is a datalog of driving it.
Base tune datalog.s3d
I titled it Base tune because thats what i feel i got. It does pull hard when i get into it (good pull couple minutes in, then a few near the end). . but nothing like it is capable of. . what it was BUILT to do. I feel like its just a pepped up basemap that i spent $300 on. . . Also it may be in Open Loop because this tuner doesnt believe in letting the ECU control economy and power together in closed loop.... and last time I changed my tune to closed loop as suggested by hondata. . . it got stuck at 2500rpm rev limit.
I apologize for the size of pictures and datalog. (Simple scans, and a single full trip datalog.) Check out my other Topic post for update and detailed Engine specs.
Re: Anybody want to check my datalog? Im concerned about it
Posted: Sun Jul 29, 2012 1:21 am
by WaZe_One87
At the very least, does someone share my skepticism about the tune? Notice how my top end HP drops substantially at 6800ish rpm. STOCK b16 redline is at 8200 and is fully capapble of making power to that point. Now I realize my wastegate opens at 5.5psi and will dump everything else. . but it should still make realatively consistant 5.5psi of boost and thus make power thoughout the rpm range as long as there is fuel to do so. . now call me crazy, but i think my 750cc injectors are more than capable to supply said fuel for such minimal boost. If you look at the calibration, take a glance at the fuel tables. . . Now again, feel free to tell me otherwise, but does the fuel output just stop is gradual increase and dive off a cliff? Right about the time my HP takes a dive as well?
E85 basetune 5psi.skl
I know im complaining, but I just dont like the idea of paying $300 for a dynotune for at least the wastegate spring. Again, i wasnt willing to pay ANOTHER $300 for my tuner to install the boost solenoid and components to the ECU, nor $80 for a boost controller plus whatever for install since i was planning on getting the solenoid and run in fixed duty till i tune for boost by gear. Would be more of a waste of money. So i settled for a tune for whatever the wastegate would give me, and i dont think i even got that. Also they did not test the two other springs i BROUGHT THEM for my wastegate. . just left them as is. And told me the manual boost controller i had was a POS. . granted it probably was, but they said i could pay them $50 to put it on just to take it off. I think it would have at the very least given me more than the spring.
My theory. . . i thought i was getting boost by gear tune for $500 but they raised that to $700 for install of solenoid and Tune. I said i cant do $700 so just give me a regular tune. They suggested $80 for a boost controller so i can push 12psi (what they thought i would max out at) with it. I said i would rather pay the $150 for the solenoid and run it as an EBoost Controller fixed. He said it cant be done. However, research says it can. . So I insisted in it. Well the price jumped to $300 for install. $300+$300=$600. . only $100 less than what they were EXPECTING me to pay initially for the full boost by gear tune. Now, doing this math in my head i wasnt gonna pay $100 more than i though i would be getting boost by gear initially at for only a standard tune. I COULDNT afford it. I alloted for the $500. Well I backed down and said no thanks, give me my emmissions tune back and i will go elsewhere. They told me the tune was almost done and would have to pay the $300 reguardless. I'm thinking Fine, whatever, give me the finished tune and i will deal elsewhere. Well. . . i payed the $300, and im thinking i got the almost done tune not a done tune because i refused to give them the money they were expecting from the start. . .
And for the record i am coming to the closest thing to HONDATA as i can about this issue, because i want them to tell me that yes they feel that A)prices are fair for install, B)that the tune i payed for is infact complete.
In a way im trying to open the eyes of HONDATA to what one of their OFFICIAL RETAILERS/INSTALLERS is doing. And if they find its perfectly fine, then I guess i need to count my losses, feeling like i was screwed royally.
