s300 V2 - AEM 30-4100 Wideband (Sure its in here somewhere)
bonang
Post by bonang »
Hi All,
I am assisting a friend in wiring his 92 Civic Hatch. He has a P28 ECU with a s300V2 installed and registered. I wired the car from front to back but I am having a issue with just the Wideband to be reconized in sManager. I have the wideband wired like this:
12v - Red - Switched source
Ground - black- Chassis with all the other gauge grounds
White - Analog 0-5v to red wire on Analog harness on the S300v2
I can not see the list of Analog inputs in s300. What I am I doing wrong?
I have read online other fourms and this one that my grounds should be right to the Thermostat housing.
Re: s300 V2 - AEM 30-4100 Wideband (Sure its in here somewhe
Open a calibration. In the Parameters window, under Analog Inputs, click on Analog 0 input and you should be able to select the 30-4100 conversion.
bonang
Post by bonang »
Thank you. I am new to this so dont mind the questions.
When I get home from work I will d this right away!
bonang
Post by bonang »
Thanks it worked. Ok so it's showing volts even when I have a/f selected for conversion. What should I do? Again I'm new to this and only getting the sensors showing correctly
Options, Settings, Units...makse sure you have it set to AF.
Double click AF in the sensor list and make sure it is set to AF as well.
bonang
Post by bonang »
Sensor list has only volts for unit
Options-settings-units is already set to a/f
The sensor list when you go double click on AF allows you to change it to AF. Volts is not an option under AF.
bonang
Post by bonang »
Unit shows - a/f ratio already
Checked display and still showing volts
bonang
Post by bonang »
I am using a0 on the s300 if that makes a diff
bonang
Post by bonang »
Thanks fellas! Working great no offset required
