Solid Cell in UKDM K20A2 Swapped in EDM 97 EK3 Kpro3
Posted: Thu Jul 12, 2012 2:00 pm
Hi Guys,
My Info:
- serial number of your K-Pro
K-PRo III R17 10472
- ECU part number (starts with 37820) and serial number (the number under the part number)
37820-PRA-E12
- KManager version (not 'the latest')
3.1.2
attached
cant yet
- what sort of vehicle you have
1997 EDM EK3
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
Clifford G5 MK2 Concept 650
Wireworx CM3 harness
Has a immobilizer (chip in key and transponderbox under the steerig colum)
Car wont swing,Solid cell and kmanager wont see switch on unless I ground the ground wire from the analog inputs.
-When and where you got the K-Pro
February 2012 from CPL UK
I just swapped a UKDM K20A2 in my EDM EK3.
wired everything up and grounded it also.
Head
Block
Gearbox
Intakemanifold
I get a solid cell,
car wont swing( just a click sound from the enginebay fusebox thats now under the dash),
Kpro only shows the switch on if i ground the ground wire from the analog inputs.
Hope you guys can help me,
Mitch
My Info:
K-PRo III R17 10472
37820-PRA-E12
3.1.2
attached
cant yet
1997 EDM EK3
Head
Block
Gearbox
Intakemanifold
I get a solid cell,
Mitch
