Primary o2 sensor disable pra
Is there anyway i can disable completly the primary 02 in a pra ecu/kal? Even in open loop throws an error and after it the engine has poor/less performance. Its a track car so i have no need for it.
playasyougo
Re: Primary o2 sensor disable pra
What error code are you getting?
If it is P0132 then the comment at the end of this thread will fix it. Dont worry about uploading base map as mentioned, you can use tuned map as long as it's for the ECU.
http://www.hondata.com/forum/viewtopic.php?f=12&t=13226
ok ill try it, altough it doesnt makes much sense to me. thanks
playasyougo
I take it that was the code you were getting?L_S_i wrote:ok ill try it, altough it doesnt makes much sense to me. thanks
If so i had the same issue and this is what i did to fix it.
1. Go into the calibration for your engine (base or tuned).
2. Go into options and click box to say you want to use second O2 for closed loop.
3. Save and upload.
Post back to let us know how you got on.
