new to hondata, need some more tips
racepak
Post by racepak »
hey guys,
i'm new to hondata. but i'v been using crome for years,
i need some help with the correct "order\procedure" of making a new map in hondata,
this is what i used to do in crome:
chk sum + rtp
p28 to p30
options
boost tools
boost table wizard
fuel tools
inj size/type
offset
set ignition with timing light.
when you start a new non boosted too booster map with hondata, is there an order to do the procedure?
a few days ago i tryed my s300 unit on a friends car,
and thats what i'v done:
new stock p28
in paramters:
set to open loop, rev limits. vtec. etc.
misc:
disable ks, disable eld, dis inj error, dis barometric sensor,
MAP: set to replacemant 3 bar.
fuel trim:
changed current injector size to 850, and set the offset table to my inj manufacturer specs, (i left the overall fuel trim at 0%, is that ok?)
SET TPS %0-100
lock timing and adjust with timing light,
when do i need to enlarge the map to a 3 bar? also, when do i need to apply the create boost table feature??
please let me know if i'm skipping anything or doing anything wrong?
thanks!
Re: new to hondata, need some more tips
The order does not matter as long as you do it before you start tuning.
