I have a Proposal for the next update
skullbasher
Post by skullbasher »
Is there any way that the hondata software team can add separate shift lights and possibly separate rev limits for each gear under the Shift Light and REV limit section of Parameters. i was figuring that this would come in really helpful when racing with street tires at the drag strip. Although i know traction control is now being worked on i also figured that with separate shift lights for each gear it would be better. This will be helpful for example when someone launches and needs to shift earlier in lets say first and second and then rev higher in third, and fourth and so on without having to keep looking at the dash to know when to shift, and also so that when you launch in first, you don't over rev to the point where there will be no traction at the rpm you land at on second gear without having to switch gears slower than normal and lose boost on top of that.
