Smanager was working fine the day before, today I hit the "check for updates" and hit download and installed it (smanager V2.0.0.0).
It no longer works, it can't download or up load calibrations but if I hit F10 numbers shows up normal and works in the display screen.
After hunt around the net found smanager v1.3.1.0 (can't remember what I had) and installed it, now everything works
fine. Would like to use the latest smanager :(
I'm new at this, I've try look for the same problem but not been able to find anything yet.
Anyone got any ideas? Any help will be great. Thanks
After software update Smanager Not working
Re: After software update Smanager Not working
When you say it doesn't work, you're going to have to give more information.
The latest SManager is 2.1.1. Please don't roll back to an older version - this can cause problems.
Post a picture of the s300 inside the ECU (high quality and in focus).
I'll download the 2.1.1 and try it again, will report back. Will upload a photo when I can.
Sorry after downloaded latest software it works fine so I've forgot to report back. No problems now and here is the photo of the S300.
justYncredible
i just installed the latest version of smanager which supports flex fuel and now my car has a rough idle and shuts off at stop lights. not sure what happen or why this is happening. ill upload whatever it is you need to help me fix this issue, thanks
