Boost control help
Lazysk8r2
Boost control help
Post by Lazysk8r2 »
Set up, JDM s300
Duel wastegates, signal wire going to A17 power going to switched fuse box. port 1 has T bracket going to lower ports. port 2 has going to top ports. port 3 is vented. PWN enabled normal closed selected. Tried duty cycle between 10% and 60% and no change in boost levels. Wires are getting power and signal. Possible bad hondata boost solenoid? Frequency 78.
I cant figure out why its not working, its a brand new solenoid. Any suggestions?
Street Tuner/Dyno Tuner
Re: Boost control help
What ECU is this in? Can you post the calibtation used as well ad a datalog showing the problem.
Lazysk8r2
Post by Lazysk8r2 »
It is in a JDM P72. Does it need the boost components added?
No additional components are needed. Can you please post the calibration used as well as a datalog showing the problem.
Lazysk8r2
Post by Lazysk8r2 »
Here is the calibration. We test solenoid and its fine. Continuity is fine on A17, and its getting power. Even through in another one same problem. Continues to run off wategate spring. Will post up datalog once i have time to get it on the dyno.
Make sure you have the boost control solenoid installed correctly for the ECU you are using: http://www.hondata.com/help/smanager/bo ... lation.htm
Lazysk8r2
Post by Lazysk8r2 »
so instead of a switched power, jdm ecu need a ground?
Correct
