Page 1 of 2
Help!!
Posted: Thu May 31, 2012 12:50 am
by shawnfuss
I installed the hondata boost controller and hooked it up as the instructions said, now my car will not idle or run while not on WOT. im stumped i have tried reloading the rev hard base map but still it dies. any help would be great!
Re: Help!!
Posted: Thu May 31, 2012 6:16 am
by shawnfuss
Also car is a 2004 civic si with K20a3 revhard turbo kit. Im running hondata kpro as well. No check engine lights come on just dies out of nowhere
Re: Help!!
Posted: Thu May 31, 2012 9:01 am
Did it work immediately before you wired in the boost controller?
See
http://www.hondata.com/forum/viewtopic.php?f=12&t=3629
Re: Help!!
Posted: Thu May 31, 2012 9:08 am
by shawnfuss
Everything was working great until i wired the boost controller in, now it just dies without warning just like turning the key to accessories. Will upload the ecu info when i get home
Re: Help!!
Posted: Thu May 31, 2012 9:53 am
Undo the changes you have made and see if it works correctly. If it does then you connected something incorrectly. Go over the installation instructions again and wire it correctly.
Re: Help!!
Posted: Thu May 31, 2012 10:14 am
by shawnfuss
I unhooked the wires from the boost controller and put it back to how it was but its still doing the same thing
Re: Help!!
Posted: Thu May 31, 2012 10:52 am
What is the serial number of the K-Pro board inside the ECU and what is the serial number on the outside of the ECU case?
Re: Help!!
Posted: Fri Jun 01, 2012 3:32 pm
by shawnfuss
Hondata Serial #10881
version 3.1.1.0
ECU# 37820-pnf-a12
142471-3y10
Re: Help!!
Posted: Fri Jun 01, 2012 5:00 pm
Go to online, tools, and click on clear security. When that finishes, close the program and reopen it , then go to new calibration and select a calibration and upload it to the ECU making sure you disable the immobilizer if it is not the original ECU from the car. See if it will start.
Re: Help!!
Posted: Fri Jun 01, 2012 5:33 pm
by shawnfuss
ok tried that and it still dies when i gave it partial throttle to back the car up. im uploading the datalog, looks like the a/f ratio spikes right before it dies everytime.
Re: Help!!
Posted: Fri Jun 01, 2012 5:37 pm
by shawnfuss
the problem happens right around 3m 40 seconds
Re: Help!!
Posted: Fri Jun 01, 2012 9:20 pm
MAP sensor is not reading correctly. Check your settings.
Re: Help!!
Posted: Sat Jun 02, 2012 2:58 pm
by shawnfuss
I have a stock map sensor. Should i just upgrade to the hondata one?
Re: Help!!
Posted: Sun Jun 03, 2012 1:48 pm
No, the MAP sensor is not reading atmospheric with the engine off, and the reading is low while running. The regulator for the vcc +5V outputs might be damaged, or something else (a sensor or wiring) is pulling the 5V down.
Re: Help!!
Posted: Tue Jun 05, 2012 5:44 pm
by shawnfuss
so i checked voltage at the map sensor with it unhooked and the key turned on. it had 5.07 volts. what other checks are there??
