CPR wiring help!!!
Posted: Sun May 27, 2012 2:17 pm
Camping onto this topic for a non-related wiring question (instead of starting a new topic).
I'm planning the CPR install for my '95 Integra GS-R, B18C1. In reviewing the instructions I see I've got harness Variation B, with Green and Yellow wires for the engine compartment distributor connections.
As I understand it, the coil and ignitor can be completely removed from the disty; correct? If so, then per the FSM the two wires on the lower plug to the disty, black/yellow and blue, will apparently be going to nothing inside the disty. I think these are the two wires that must be connected to the green/yellow wires on the CPR harness.
If these assumptions above are all correct, is there any reason I cannot simply cut off the socket of this lower connector from the distributor and use that as a pigtail to connect to the CPR harness? It would make the installation cleaner, waterproof, and easily removed for subsequent engine removal. It's a race car, I'm not worried about putting it back to stock ignition.
What are folks doing with the internal wires that used to go to the coil and ignitor? Cutting them? Taping them off and stuffing them inside? I want to ensure they stay clear of the shaft/gears/Hall Effect sensor.
Greg
Greg
