Page 1 of 2
s300 bogging
Posted: Fri May 18, 2012 2:46 pm
by Dkgsr
ok so my car is not tune yet, but i have to get it running better than now to get it to my tuner.
i have an integra gsr turbo with a gt35r turbo and stock injectors so far.
i have 1000cc's but i don't have them in yet because i still need the clips for it.
my issue is that when ever i go on in incline or a slight up hill from a dead stop it bogs and than sounds like its going to die.
my Tps sensor is at 1.81 at minimum and 101.69 at maximum. (is that ok???)
I tried leaning it but nothing changed, i also have a narrowband gauge.(just for now until i get a wideband gauge and sensor)
Re: s300 bogging
Posted: Fri May 18, 2012 3:07 pm
Wait until you get the right injectors installed. Running boost on stock injectors is just asking for trouble. If you are not careful you will damaged the engine.
Re: s300 bogging
Posted: Fri May 18, 2012 5:04 pm
by Dkgsr
alright, ill wait till i get my 1000's in and see if it still does that.
but when i d/c my Intercooler pipping and try running it all motor it still does that. Only CEL that came on was for my knock sensor.
and i disable that from the s300.
could it be something else??? i know that when i had the 3Ibs spring in my map sensor was leaking and was bogging, but got that fixed.
could i have damage the map sensor some how?
Re: s300 bogging
Posted: Sun May 20, 2012 8:17 am
by Dkgsr
so im guessing the sensor should be fine than???
Re: s300 bogging
Posted: Mon May 21, 2012 10:01 am
You will have to datalog and check the map sensor readings and see if they look correct.
Re: s300 bogging
Posted: Tue May 29, 2012 12:33 pm
by Dkgsr
so how is it suppose to look like. my map readings read -29.5psi at idling. ill up load a data log later on today if i have time.
thanks.
Re: s300 bogging
Posted: Wed May 30, 2012 7:42 pm
by Dkgsr
sorry have to do this to transfer this map to another computer.
Re: s300 bogging
Posted: Sat Jun 02, 2012 12:29 pm
by Dkgsr
ok so i have the 1000's in and its still doing the same thing after i have altered the map to make it start.
can't think of what's going on...
Re: s300 bogging
Posted: Mon Jun 04, 2012 9:32 am
You will have to have someone look at your car to see if they can see any insallation problems with the fuel system. Let them know everything you have changed or worked on.
Re: s300 bogging
Posted: Sat Oct 20, 2012 3:37 pm
by Dkgsr
here's a log. There is no leaks or anything. Just doesn't go past 2k rpm. Only once in a while it well go to 2.5 to 3k
Re: s300 bogging
Posted: Sat Oct 20, 2012 5:59 pm
by Dkgsr
My mods are:
Custom mini ram
Gt35R ebay turbo
precision intercooler
Nippon low comp. piston
Eagle head studs
cometic .30 headgasket
ITR cams
Re: s300 bogging
Posted: Mon Oct 22, 2012 4:42 pm
What is the fuel pressure on the rail itself? What is the fuel pressure before the rail? Make sure you have the washers installed correctly on the banjo bolt fittings on the fuel line going to the rail.
Re: s300 bogging
Posted: Sun Nov 04, 2012 10:12 am
by Dkgsr
i don't have a gauge to tell me what kind of fuel pressure i have. I'm pretty sure the "O" rings on the fuel rail is on right. Can't think of anything else.
Re: s300 bogging
Posted: Mon Nov 05, 2012 11:23 am
There are no o-rings, there are washers and if installed incorrectly you will get very little fuel.
Re: s300 bogging
Posted: Tue Nov 06, 2012 10:50 pm
by Dkgsr
sorry, my fault about the washers.
I checked it and its installed correctly.
Would an open wastegate cause this to happen?
