Ok guys i got a map from a buddy and uploaded to the ecu. It starts and runs but you have to keep giving it gas to keep it running.. Can't get it to idle. Also the map had the cylinder fuel trim for cylinder 4 with 1% and cylinder 3 at 2%. Should i change these to 0?
Something else i didnt understand is when car was running, my ram horn manifold was super hot on the 4 cylinder exhaust exit of ram horn, all the other parts of the ram horn you could touch with out worrying about burning your hand.What would cause that to happen?
Here is my setup
B16a2
Manley H beam rods
CP 10.5:1 pistons b16a2 .020mm over
Supertech Nitrate coated racing valves, titanium retainers, dual racing springs locks
Gsr Cams
63ar t3/t4 turbo
38mm tial wastegate
2.5" exhaust
percision 1000cc injectors
Please help me get the map to a driveable state so i can get the car to the tuner...
Thanks in advance for the help.
Can someone check my map and datalog for B16a2
Monnoracing
Re: Can someone check my map and datalog for B16a2
see if it will idle for you now.
