K20A2 Alternator giving over 15v, wiring issue
ukir85
Post by ukir85 »
Hi
I have a K-engine with oem Nippon Denso alternator.
The alternator is givine over 15v, I guess this is not correct as that amount can boil/ruin the battery?
I have not connected alternator to ECU at all, as my ECU can't control the alternator.
All I have done is, I have connected blue/white cable (If remember correctly) to +12v which wakes up the alternator.
Should I connect something else to somewhere else as well to get the lower output voltage from charger?
Thanks, for the tips.
