Page 1 of 2
FlashProManager V1.3.3
Posted: Wed May 09, 2012 1:39 pm
2009-2010 TSX Support
Quickspool
Holds the wastegate shut until just below the target boost to spool the turbo quicker.
V1.3.0 Changes
  • FlashPro firmware updated to version 45
  • Added support for the 2009-2010 TSX.
  • Added long term fuel trim min/max to closed loop parameters.
  • Changed Check For Updates to show current version number and release dates for both beta and production releases.
  • Added quick spool to boost control.
V1.3.1 Changes
  • Fixed Conversion exception when checking for updates with non-English language settings
V1.3.2 Changes
  • [S2000] Added minimum ignition timing tables.
V1.3.3 Changes
  • [Civic Si / CTR] Added VTC deceleration angle control.
    [Civic Si / CTR] Added gear ratio correction for ECU gear detection as well as cruise control.
  • [Civic Si] Added boost cut, fuel overrun cut delay, second ECT sensor, VTC cam angle index.
  • [Civic CTR - Euro] Increased maximum cam angle to 50 degrees, added warm up retard table.
  • [S2000] Changed P2A00 error threshold.
Re: FlashProManager V1.3.1 (Beta)
Posted: Thu May 10, 2012 2:13 am
by mabo
Very RAW release.
First, i still see 1.3.0 on top after i installed 1.3.1,
it constantly shows error
It still show 1.3.0 in check for updates and after i press download 1.3.1 it throws error - update.exe isnt win application.
Posted: Thu May 10, 2012 4:21 am
by IcEMoCHa
Unable to open any calibrations using this version.
Posted: Thu May 10, 2012 10:43 am
by VaporBomb
I am getting the same error. I also cannot open any cals. This was my first install, and I have uninstalled it. Should I try to reinstall v1.3.1, or is it ok to just download v1.2.8?
Thanks for any help.
Posted: Thu May 10, 2012 3:35 pm
It has been fixed. Try it now.
Posted: Thu May 10, 2012 5:49 pm
by VaporBomb
Spunkster wrote:It has been fixed. Try it now.
Seems fine now.
Posted: Fri May 11, 2012 9:55 am
by mabo
Works fine , thanks guys. Please dont pull out old one before you see new one is working )
Posted: Sat May 12, 2012 4:03 am
by beaugus
In regards to the recent addition of "Added long term fuel trim min/max to closed loop parameters" - does this adjustment allow us to virtually "disable" long and short term fuel trimming on MAF/MAP hybrid calibrations by making the values "0" and if so are there any significant concerns by doing this?
My FN2 is running a hybrid MAF/MAP tune at the moment and the fuel tuning is virtually flawless but the short and long term fuel trimming is affecting my tune the longer I drive and have been waiting for the option to disable fuel trimming and hoping this new option finally allows me to do this.
Just wanted to be 100% sure before I commit to making changes to my tune that I'm correct in saying that changing the values to 0 will esentially disable short/long fuel trim whilst in closed loop.
Posted: Sat May 12, 2012 5:51 am
by mabo
Re: FlashProManager V1.3.2 (Beta)
Posted: Thu Jun 14, 2012 10:22 am
by mabo
i had 1.3.1 on second PC , selected check for updates option , pressed download 1.3.2 ang got this
Not shure latest build have this error but i cant check it )
Posted: Fri Jun 15, 2012 9:19 am
Anti virus software is removing the update.
Posted: Sat Jun 16, 2012 2:58 pm
by mabo
Sorry but its not an a-virus tricks. Its system error, before i posted i tried it on clean VM and disabled antivirus on regular system and got same error.
Posted: Sun Jun 17, 2012 6:52 am
Then use explorer to check the update.exe file in your User directory, and see if the file runs directly.
Posted: Mon Jun 18, 2012 10:41 am
Try downloading the update directly from the downloads section of our website.
Posted: Sun Jul 08, 2012 1:49 am
by mabo
Hondata wrote:Then use explorer to check the update.exe file in your User directory, and see if the file runs directly.
I tried , this file is zero length ( 0 bytes ) and i cant open it, same error. I disabled a-virus and reinstalled manager , same result.
