CAM angle not changing
tshay
Post by tshay »
Hello Hondata,
I have a 2007 si that is turbocharged and its running the base calb for greddy 370cc. i have not changed the maps in anyway and my cams on the display menu arent changing the display says they are a 0 at all times why is this and how do i fix this.
Thanks,
Tshay
Re: CAM angle not changing
Possibly because of errors. Can you post a datalog?
tshay
Post by tshay »
thanks for responding this is my data log as well as the calibration im running.
TURBO410MAP.fpcal
greddytunedata.fpdl
Error P0113 - intake air temperature sensor high voltage
On the Civic Si the IAT is part of the AFM. Is it still connected?
portmaster
Post by portmaster »
I would add fuel to your cal or stay completely out of boost until you get a tune. You are way too lean in boost. In your log you are at 3psi of boost with a 14:1 AFR that is like a plasma cutter to your pistons and rings.
And your fuel trim is adding like 40+% fuel for you. But when you go into open fuel status fuel trim can't save you anymore.
tshay
Post by tshay »
i thought the 12 to 15:1 a/f was acceptable?
portmaster
tshay wrote:i thought the 12 to 15:1 a/f was acceptable?
Not under boost you need to be low 12's unless you're running above 12psi would want to be closer to 11.5
