JDM D15B
3.4 Pulley
P28
330cc
DC 4-1 Header
Skunk2 70mm Exhaust w/ OEM Cat
Injen CAI
Boost 9-9.5 psi
Full Dyno Tune with 22 pulls
Made 172 HP- 135tq
D15B w/JRSC- 3.4 Pulley
Monnoracing
Re: D15B w/JRSC- 3.4 Pulley
Just looked at your map. Do you have a cooling system on the engine like snow or devils own? What a/f are you seeing? You need to be careful with a sc that has no cooling system. Ihave been down this road a couple times. I do nnot have a cooling system yet. My a/f are 10.9 to 11.3 to cool down the cylinder temps. I did notice your tuner did a good job on ignition table but you do not want to see 12.0 + a/f ratio at all unless you can keep your IAT's under 150. Facebook me if you have any questions http://www.facebook.com/Monnoracing?ref=tn_tnmn
Monnoracing
Here is my map setup for your stuff if you want to try it out.
