Car:1994 Honda del Sol EG2
ECU: P28
Wiring is stock, no knock sensor. No O2 Sensor. The Innovate LC-1 is connected as both the O2 sensor and as a Wideband
Wide band is connected to B6: analog input2, narrowband cable is conected to stock O2 sensor input pin on ECU.
Problem:
Lambda sensor overlay is reading different from the datalog value and the display value for analog2. Lambda sensor overlay is reading low 10's while analog 2 and the innovate gauge are reading 14-15's while cruising. The innovate gauge and the display value under the "sensors" section in the Smanager are reading the same value. The feature was working correctly before downloading the update. Tried changing the sensor overlay settings to "user defined" and tried both "wide band (AFR)" and analog2 with no success.
Lambda sensor overlay table issue
