Analog Bosh Wideband O2
William5683
Post by William5683 »
would it benefit at all to spend the money on a Analog Wideband O2 and run it full time on my primary O2 Sensor for my Flash Pro on the CR-Z? Would there be any difference in the performance or auto-tune's ability to compensate for more precise changes?
Re: Analog Bosh Wideband O2
THere would be no performance gain by doing this. The factory sensor is a wideband.
William5683
Thanks for the info the voltage range did seem that it was in the range for a wideband but I wasnt sure. Thanks you
William5683
If it is a wideband can we go into settings and change from stock sensor to corrected or analog wideband input? If it is in fact a stock wideband then we should give the Flash Pro the ability to calculate or the voltage range of .5 to 4.89 the basic range already. Hondata what is your opinion on this?
