new n/a h22a build
integra_22t
new n/a h22a build
Post by integra_22t »
ive got a h22a with full n/a build and trying to run off the s300 software
the build is :
h22a block
ported and polished head
skunk 2 retainers
skunk 2 springs
stock valves
skunk2 pro+1 cam
skunk2 cam gears set at 0
venom 440cc injectors
afpr at 30psi
skunk2 pro intake
69mm throtal body
eagle h-beam rods
wesco pistons 11.5/1
hytch header
full 3" exhust
ive tryed 3 diffrent tunes ( one thet comes with the s300),h2b type s , and the mikes tune
alltunes make the car so rich i should put a can at the tail pipe to chatch the extra gas lol
if i put the stock h22 ecu the car runs better but i want to use the s300 and get the car right
if i back off the fuel pressure the car runs better so i know its a fuel problem .. and yes i know 30 psi isnt enough
any tunes that might be good for this or how can i back off the injectors to get the car to lean out
thanks
integra_22t
Re: new n/a h22a build
well here is the first set up that let the car idle
after that i upped the fuel pressure to 42 with the vacume line off and backed the injector dead time and think the car was a little on the lean side as the header is starting to turn purple after the nice gold colour
i sent off an email to venom asking for the dead time but havent heard back ... the ones i used are for the stock h22 injectors from 92-96
It sounds like the injecotrs may be leaking if you have removed 80% from the fuel trim and it is stilll rich and the only thing that makes it better is reducing the fuel pressure.
integra_22t
ill have a look at that
i got tired of trying to get the s300 to work so i put the stock ecu ( unknown chiped) back in and the car runs alot better i could get the car to rev and hold a decent idle for what it was worth
im still going throu all the s300 info so hopefuly i can find something
integra_22t
found a h22a7 tune and its alot better .. at lest the car is idling at 1500 and i can give it some throtal but it want to stall under 1500 so im going to start playing with that tune to get it close
ill let you know tomorow how it goes
integra_22t
well im close to haveing the car leave
found out that i wired the map sensor backwards and after trying the ecu in my own car figured out some things
now the car is at idel around 1000 ... cant get any lower as it wants to stall .. thinking its becouse of the cams
still sitting a little rich but not to bad .. backing some of the fuel trim as well as the duty cycle and dizzy timming ... getting close
integra_22t
wow what a learning curve
ok so i took the car out today and it still wants to die at idle and as you get into the trotal the car wants to break down but as soon as you get around 5000rpm the car evens out and runs great .... so i have to figure out whats diffrent between 0-5000 and 5000+ and i think it will be tuned enough it can go to the dyno for a better tune.. i just dont want him to blow the motor up
Mikes stock H22a tune- best tune so far-5.skl
1st test.s3d
thanks
Monnoracing
Post by Monnoracing »
Do you have a check engine light? You need to mmake sure all CEL codes are delt with befor tuning.
integra_22t
thanks and yes i have no cel
the car is ok and set up till 5000rpm and now working on the cold start ... have to get this finished
this is my best cold start so far
integra_22t
well the car is tuned enough for the car to leave
cold start is ok but dipps alittle after start but is ok
for the first while in the datalog i was playing with fuel at idle and found out that if the car ran alittle rich it didnt lope at idle
Kroy4king
Post by Kroy4king »
integra_22t wrote: Thu May 17, 2012 1:59 pm well the car is tuned enough for the car to leave
Hi mate got the same problem as you had was wondering if you finally got it sorted?
I'm running the same sort of setup as you
Engine: h22a/stroked h23a
Compression: 12:7:1
Valve train: full Ferrea race setup with 1mm+ oversized valves and 5 angle valve job with port and polish
Cams: stage 2 skunk2
Cam gears: skunk2
Engine: balance shaft delete
Injectors: sard 800cc
Fuel rail: aem high flow rail
Fuel pump: 340l Walbro fuel
Regulator: aem adjustable
Intake: skunk2 pro series ported to 70mm
Throttle: pro skunk2 70mm
Engine: lightened pulleys
Headers: skunk2
Exhaust: skunk mega power 3"
