s300 with plx wideband/datalogging
y2k1
Post by y2k1 »
I have bought s300 socketed on p28 ECU. I also have the PLX wideband along with the gauge. My engine is b16a/b20b with p30 jdm ECU and I have questions...please help
1. For the ECU, is it just simply load the p30 jdm ecu profile to the hondata ecu?
2. I saw on the hondata site about "White 0-5V Output from wideband - connect to ELD input making sure that the ELD is no longer connected to it (ELD is pin D10 on an OBD1 ECU)" is there any wiring diagram or photos of the physical connection (just to make sure I dont cut the wrong wire?
3. "Some ECU's may need to have resistors R136 and R138 removed to improve wideband reading accuracy in the software." Is this necessary based on my ECU? How do i know that I need mine removed/not? is it after when I adjust the voltage inside hondata and still cant get the correct reading?
I have searched around and cant seem to find the walktrough with wiring diagrams anywhere. Please advice for this new guy on the block..
Thanks a bunch........
Re: s300 with plx wideband/datalogging
ECU connectors: http://www.hondata.com/help/smanager/ecuconnectors.htm
Try it without cutting the resistors, but if you have any problems with the readings being acurate then cut the resistors.
