Doesn´t write in estimated fuel change and datalogged lambda
Jim_H
Post by Jim_H »
Hi!
Before when I used my S300 and I was datalogging the lambda value showed in "Recorded/Datalogged lambda value" and in the "Estimated fuel change in order to reach lambda" the values came up directly and then change as you go over the same points, as it should. Now when I´m datalogging everything is working correctly, except for the part a just mentioned. I can see my lambda value and water temp. etc in the display, but the values don´t come up in the tables. Is it something in options I may have changed?
The car: Civic EE9
B16a2 motor
OBD1 converted
Using thermostat ground and datalogging via ELD D10, resistors cut, can´t remember the names.
It has all worked before, why do I have the problem now?
Think it started since I updated to Smanager 1.6.
Please give me a hint of what I´m doing wrong.
// Jim
Re: Doesn´t write in estimated fuel change and datalogged la
Try downloading the most recent beta version of software from the downloads section of our website.
Jim_H
Post by Jim_H »
I have downloaded 2.0 and it still doesn´t work. Is this something that always is on or you can turn it off somehow?
Post your calibration and a datalog showing the problem.
Jim_H
Post by Jim_H »
Here´s a datalog and the calibration. But here everything seems ok. If I have recorded, and then upload my datalog, the values come right up, afr and estimated fuel. But the problem is when I am live, I want the values to come right up on the screen directly, don´t want to have to upload the datalog to start seeing the values. It has been that way before but why does it not work now? If it is like this you can´t see which columns you have covered when you go out tuning..
IT is working as it is supposed to. Check your sensor overlay settings.
Jim_H
Post by Jim_H »
Came out today, started my car as usual, and started datalogging. And now it works!! I don´t know what the problem was? Anyway, it alla works now and the datalogged lambda comes right up on the screen and so does the estimated fuel change! Thank you for your time.
lowblow
Post by lowblow »
I have the same issue!!! No estimated fuel change and data logged Lambda?
Check the settings
lowblow
Post by lowblow »
It's working before with old version. I have download most new version now.
Which seting I should go?
Options, Settings, Sensor Overlay
lowblow
Post by lowblow »
Is working now! Thanks You...
