Why is only 1 cylinder knocking so bad!?!
tec_neak
Post by tec_neak »
Let me start off with my mod, Injen cai and flashpro. Everything else is completely stock and the car is just reaching 40,000 miles.
So this log was taken from a 1hour and 30min drive. The problem is obviously knock, but it is only happening in cylinder 4 and it is happening at a very rapid pace. It is hard to reproduce this problem it only happens in 1 out of 4 logs that I take. I notice that it happens when I am at a constant load in 6th gear, mainly around 65 to 66mph. I have tried flashing back to a base calibration but knock still occurs. Which lead me to think it was a mechanical problem. I have also tried changing the spark plug, running injector cleaner, but that specific case still occurs. Im not sure if it is the tune, or if it is a mechanically problem. I also attached a picture of the ignition map, is there anything wrong with it?
Any input on this would be greatly appreciated!!!
Re: Why is only 1 cylinder knocking so bad!?!
Try the AFM calibration as it has ignition timing closed to stock.
Reduce the ignition timing for all cam angles by 2 degrees. If the knock decreases, then it is over-advanced. If not, then it is mechanical noise. Exhaust systems & engine mounts can cause this - sometimes just a loose bracket in the engine bay hitting the engine. You could also decrease the ignition timing just for cylinder #4 by 2 degrees to see if that helps.
tec_neak
Post by tec_neak »
Thanks for the reply, currently I have parts of the ignition map that was effect by the knock retarded by 1 degree. I'll continue to keep collecting logs until I the problem is reproduced again and see if there is a difference. If there is I will degrees the affected areas by another degree to see if it helps. Since the knock doesn't happen every single time this process is going to take a while until it can be reproduced.
And you said simple things like a loose bracket could cause knock, what about noisy valves? Is it possible that if I adjust the valve lash the knock would go away? I do hear a ticking coming from the head but Im pretty sure the ticking is coming from the injectors but I could be wrong.
