It appears that there is only one set of supplied Knock tables for all existing base .kals. Further, it appears that the tables are position-based, rather than RPM-based. There tend to be two high speed RPM scales typically used in the supplied kals, one which goes from 3000-11000, and the other which goes from 1000-8500. Which were the tables designed for?
For example, the two NA base kals for the TSX Dual Adapter (one is "Stock w/91 fuel", the other is for common bolt-ons, both with 310 injectors). The former uses the 1000-8500 scale, while the latter uses the 3000-11000 scale. The actual table entries are the same, though, based on position...not RPM.
Which table scale should I be using to get the correct corresponding values?
Secondly, where did these values come from? In stock form, an RSX K20A2 is going to have a different ignition profile than a TSX K24A2, so knowing what the supplied tables came from would help in determining how much adjustment may be needed.
Thanks!
Knock table RPM scale question
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
