Lean Start cold engine
Posted: Wed Mar 28, 2012 6:35 am
by yangeghatch
Hi guys,
I got a D16z6 with vitara internals w/ Greddy TD04 kit
I started a new calibration and started engine
Engine starts but it is leaning out.
I think it is because the engine is cold.
Is there something on the parameter that I need to adjust?
Also if you can provide me a link that would be very helpful.
Thanks.
Re: Lean Start cold engine
Posted: Thu Mar 29, 2012 9:21 pm
by hpmx18
check the fuel compensation tab for water temp & air temp
Posted: Sat Mar 31, 2012 6:07 pm
by yangeghatch
hpmx18 wrote:check the fuel compensation tab for water temp & air temp
I didn't play with them. Hints on this? Thanks.
Posted: Sun Apr 01, 2012 1:40 pm
by hpmx18
let the car cool down to where its cold enough to duplicate the same symptoms and see wat table needs a bigger % on the same tab i was referring to
Posted: Thu Apr 05, 2012 4:22 am
by hondatechpr
First check if the coolant sensor is connected and working.
Posted: Thu Apr 12, 2012 7:26 pm
by yangeghatch
Still haven't had a chance to try it out yet...
Do you guys usually leave this area stock when tuning or did you guys add more fuel?
How much do you usually add? ( I know it varies between setup just want an idea)
Thanks.
