Re-reflash Needed After Blown Head Gasket/Engine Replacement
Akuku2
Post by Akuku2 »
Does my ECU need to be reflashed in the case mentioned in the subject? A mechanic did some shoddy work [shouldn't have gone to him] and my head gasket blew, was worked on [same guy], then the whole engine blew. As far as the replacement engine goes do I need to have the ECU reflashed? I haven't even touched 4.5k rpm since cause I'm worried..
Re: Re-reflash Needed After Blown Head Gasket/Engine Replace
I'm sorry, but I don't understand the question. Has it been previously reflashed? Has it been replaced with the same engine?
Akuku2
Post by Akuku2 »
My bad. Yes it has been previously reflashed, and it now has a new engine.
Akuku2
Post by Akuku2 »
Bump for reply.
You have left out some key details: what engine did it have, what engine was put in?
Akuku2
Post by Akuku2 »
Sorry again.. 2008 Si, k20z3 replaced with a k20z3..
You don't need to do anything then.
Akuku2
Post by Akuku2 »
Awesome, thanks for your help/time.
