HELP!!
Posted: Sun Mar 25, 2012 1:43 pm
by poglife
i bought a 96 civic with a b18c1 turbo somewhat recently and i hooked up my computer to maybe do some fine tuning and now my car wont even stay running. which is disappointing since i dont think i even changed anything... could you guys check out my calibration and see if there is any glaring error that would cause that? i would appreciate it enormously. since this car is supposed to be my dd.
Re: HELP!!
Posted: Sun Mar 25, 2012 7:22 pm
by keto06
stock injectors?
Re: HELP!!
Posted: Mon Mar 26, 2012 2:02 am
by poglife
i was told 440. but the calibration says 240. i tried changing that but that didnt help.
Re: HELP!!
Posted: Mon Mar 26, 2012 12:38 pm
by keto06
try and mess with the overall fuel trim and see if that helps. its a bandaid, but it may help get your car running.
Re: HELP!!
Posted: Mon Mar 26, 2012 3:52 pm
by poglife
i just tried that and it didnt really change anything. i can keep it running if i keep punching the gas pedal so it doesnt die. but it bogs down if i try to hold it and stinks something horrible. its definitely not running anywhere near right. any other ideas?
Re: HELP!!
Posted: Mon Mar 26, 2012 3:56 pm
by keto06
Ive seen this happen before. Is the motor built or stock?
Re: HELP!!
Posted: Mon Mar 26, 2012 4:16 pm
by poglife
built. eagle rods, supertech valve springs, mahler pistons, 9.5:1 compression.
Re: HELP!!
Posted: Mon Mar 26, 2012 4:20 pm
by keto06
figured that was it... I bet it has something to do with the compression...
Re: HELP!!
Posted: Mon Mar 26, 2012 4:22 pm
by keto06
stock cam gears/cams at 0/0?
Re: HELP!!
Posted: Mon Mar 26, 2012 4:30 pm
by poglife
Stock gsr gears. Not sure about timing
Re: HELP!!
Posted: Tue Mar 27, 2012 5:33 pm
by poglife
Its looking like I accidentally wiped the calibration... it was trying to use a stock one which obviously didn't work. I just need one good enough to get to the exhaust shop and tuners. What stock map should I start with? For a built turbo b18c1
Re: HELP!!
Posted: Sat Apr 14, 2012 6:03 am
by poglife
any help would be appreciated... just need a map good enough to get it running. i tried using the b18c5 revhard map and just tune the fuel but i didnt see any change. still wouldnt run. i really need some help im pretty lost here...
Re: HELP!!
Posted: Tue May 01, 2012 2:57 am
by poglife
Well thanks for all the help. Not. Might as well delete don't need it anymore
